Z20LET 62mm throttle body
Op zoek naar onderdelen.
Re: Z20LET 62mm throttle body
Oeh, interesting... Wat is het voordeel? :)
Enlarged & modified Throttle Body for Z20LET/LEH engines.
Vastly improves Airflow and Throttle Response. Fully stripped down and inspected, then vapour blasted to bring it back to an 'as new' condition. The bore of the throttle body is then enlarged from 57mm to 62mm, and the spindle is re-profiled. The unit is finally reassembled with the low profile spindle and enlarged butterfly and then fully tested. Any worn bearings and motor brushes are replaced as a matter of course, so the item is essentially a fully refurbished as new item but opened out to a 62mm bore, 5mm larger than the original spec. Usual gains of 5-10 BHP are to be expected (depending on vehicle spec)*
Weazle
Bericht door Weazle »
Ja dat is ook geen kleine schuur bij jouw hahahaha :D :lol:
Top Herman :yes:
