rapidos
rapidos
Bericht door rapidos »
Outside extinguisher and electric cut commands:
Without turbo is...faster !
472gr :roll:
Clear vision now !
Rear bonnet open command :
Front bonnet open command :
This is replaced by a basic on/off switch for ventilator :
SRS central :
rapidos
This is heavy CF with high charge Epoxy due to exhaust proximity.
OEM weights 3.75kg... It does not spread the heat like the metal one to the chassis.
With NACA and deflector integrated: -25gr
Laatst gewijzigd door rapidos op 17 dec 2008 9:40, 2 keer totaal gewijzigd.
alain
Bericht door alain »
I 'm also working on reducing weight !!
No beer, no french fries and lot of sex !!!!
AND
2 months work in the gym !
- 4kg !!
:D :D :D
Me too, I weight 61 kg 8)
rapidos
Herman schreef:Less results on the driver means more work on the car .... :?
Now you understand why I work so hard on the car.... :lol:
rapidos
I don't think it will be possible. I hope I will be ready by April, but as the car will need to full repaint, I assume it will not be ready before May... :?
@rapidos
I asume you mean you will remove the paint alltogether to save weight right :wink:
rapidos
Smiley schreef:@rapidos
No. As the car is still road legal, I need a paint on it. So I will probably go for something still not done on any speedster, something sporty !
No carbon fiber today :( but minus 0.78kg ! :D
Laatst gewijzigd door rapidos op 18 dec 2008 20:40, 1 keer totaal gewijzigd.
rapidos
Today I start a difficult item...
The gain in weight is 0.58kg.
Here are the three NACA I will fix on the main carbon bottom plate. Only few grams of gain here (25gr...) but those are fire resistant and will be directly fixed on.
Laatst gewijzigd door rapidos op 02 jan 2009 15:43, 1 keer totaal gewijzigd.
rapidos
Yesterday evening, I took out the heating system. What a MESS ! :?
My new antiroll bar: more rigid (X2.25)
My snap-off
rapidos
Herman schreef:Snap-off is very heavy, that will help.
Stronger anti-roll-bar adds weight?
I think the delta from "with and without airbag" is still positive for me. I assume close to 1kg of gain. I will calculate it when everything will be fitted.
Same for the ARB. I will weight the OEM (I assume lighter).
Herman schreef:Will you remove ABS (pump and parts) as well?
No. I keep the car road legal till 2010 minimum. Then.... :arrow:
