rapidos
rapidos
Bericht door rapidos »
Smiley schreef:If the roof, back and frontclam work out, have you considered reselling them?
Sorry I don't understand. You ask me if I want to sell my new body ?
I was asuming that your new clam was built from scratch, use a mold.
Or did you modify your existing clams, and roof?
rapidos
Everything is coming from molds you are right. I always keep the original part just to be able to go backwards to oem car.
There is no aftermarket clam supplier available other then opel, as far as i know.
That makes your production very interesting, should you consider to reproduce.
rapidos
I would go for something like the Artega, at the very rear of the car, extracting hot air.
Maybe the following is an answer to your temperature issues:
http://www.lotus116.de/blog/speedster022.htm
(you need to scroll down until the part of 04.10.2008)
Regards,
rapidos
the-duke schreef:Maybe the following is an answer to your temperature issues: Regards,
I already have a diffusor extracting the hot air on the center part. ( http://www.speedsterclub.nl/phpBB2/view ... 6578#56578 )
Today I had a hard time as it was the day to cut the rear pc for lights ! No error possible, so I spent 2 hours drawing very carefully on the car and finaly went for the real job. :?
This is the glass fiber piece fixing the lights inside the body... works well !
It will looks someting like that...
rapidos
Some news...
The wing feet are now fixed on the chassis.
You can imagine it needs precision as the whole rear body is coming on it... Fisrt one...
...and second one:
I now only need to take away those six screws to move the rear body and access the engine bay, compared to the numerous hours on oem...
From behind, the lowest position of the wing.
rapidos
Herman schreef:Again, impressive work, looks great :!:
If you need to remove the wing for an oil/water check, perhaps there are ways to make it even more easier with a quick-release system? Or will the Lexan part be removable mounted?
Well I am not a specialsit in quick release systems... As a start, I will turn the screws, but if I find an easier solution, why not ! The Lexan is quite small so not possible to do/look anything properly even if movable...
rapidos
Final cut.
rapidos
Small update. I fixed the wheels arches with carbon, very light too, and now the full body can move free:
rapidos
An option...
:woship:
