Geplaatst: 13 aug 2010 12:23
				Opel Speedster / VX220 & Lotus Elise / Exige parts
Van twee Franse bedrijven TAT & DLC:
http://www.tat-concept.com/EN/
VX220 / Opel Speedster:
Exterior: Diffusers, Door sill guard, Battery bracket, Light battery, Jack bracket, 12.9 hub bolt kit, Stainless hub spacer, Carbon boot holder, Customized front grill, Racing tow hook
Motor: Alternator kit, Air intake, ALU expansion tank, Oil radiator, Water radiator, ALU fuel tank, ALU cap, adaptator gauge VDO, Intercooler bracket, Turbo tube bracket, NA tube bracket, Turbo beam bracket, Jack bracket, NA Motor plate, large turbo collar, Gearbox air intake, carbon boot holder, ECU bracket, Bigger Intercooler, ALU stop boot, Boot water plate
Cabin/Interior: Brackets, Gear grill, Gear knob, Harness seat adaptor, Leathers steering wheel, Leather side pocket, Leather seat, Sport pedals, Extinguisher bracket
Carbon part: Turbo carbon air intake, Carbon diffuser, N/A carbon air intake, N/A carbon VS ALU air intake, Carbon boot holder, Texalium diffuser, Carbon sill door, Intercooler intake Exige S2
Braking: Sport pedals, 308 Brake kit, Brake venting kit, Bleed adaptator, Hub bolt 12.9, Calliper spacer, Stainless hub spacer, Big AP brake kit, 308 dics alloy bell
Geometry: Titanium toe link + UNIBAL end rods, Titanium toe link + VX/OPEL end rods, Stainless hub spacer, Hub bolt 12.9
Lotus Elise / Exige:
Alu cap S1 / S2, Jack bracket S1 / S2, Intercooler carbon intake S2, Water Radiator S1 / S2, Bracket S1 / S2, Battery bracket S1, Battery bracket S2 Toyota, Dry battery S1 / S2, ALU Tank S1, ALU Tank S2 Toyota, Diffuser S1 / S2, Throttle bracket LHD, Leather steering wheel, Battery bracket S2 Rover, Customized grill, Extinguisher bracket S2, Light Air intake bracket S1
Lotus 340R:
alfano / VDO gauge bracket, New water radiator 32 ou 40 mm, Modified radiator 32 ou 40 mm
Lotus Caterham:
Diffuseur S3
Mini Rover:
Coil bracket
Gifts:
Garage Plate, Key fob, TAT Gifts, Carbon earring
Lotus 340R:
Lotus Caterham:
Diffuseur S3
Mini Rover:
Coil bracket
Gifts:
