Berichten: 7419 Lid geworden op: 10 jul 2008 21:46
Bericht
door Smiley » 20 okt 2010 20:10
How much did you save on cutting the baguage space out of that clam?
rapidos
Berichten: 367 Lid geworden op: 25 okt 2007 5:37
Bericht
door rapidos » 21 okt 2010 5:42
4.63kg
rapidos
Bericht
door rapidos » 31 okt 2010 8:45
Just had this as a surprise yesterday evening with friends...
It was delicious !
rapidos
Bericht
door rapidos » 10 nov 2010 8:42
Last engine fine tuning yesterday. The fuel pomp was not running perfectly after 4200 rpm, but now...
Nice turbo effect from 3000 à 4000 tr/mn...
I start now the light weighting program for the winter...
Berichten: 2481 Lid geworden op: 02 okt 2006 19:28
Bericht
door Herman » 10 nov 2010 20:32
2017 target: Spexige 550+pk/840kg , Europa SE 329+pk/995kg
rapidos
Bericht
door rapidos » 11 nov 2010 6:52
Nothing special or notable.
rapidos
Bericht
door rapidos » 14 nov 2010 7:42
Now in place...
Bericht
door Herman » 14 nov 2010 10:52
rapidos
Bericht
door rapidos » 14 nov 2010 13:30
It will come later, but I prefer to focus on big saving parts at the moment...
First test on chassis :
A LOT of air !
The exhaust pipe will be side located.
I am going now to create the carbon pieces that will support both the rear body and the rear wing. What height should I use according to you ?
Berichten: 1663 Lid geworden op: 15 jan 2006 22:01
Bericht
door Dominique » 14 nov 2010 16:46
rapidos schreef: Now in place...
I've seen the engine mount at Herman's place.
Compliments, it looks great: you should make a gap in the clam to make it visible!!
rapidos
Bericht
door rapidos » 15 nov 2010 7:00
You will see it by the center hole...
and also one new special part on the chassis.... schuuuut ...
rapidos
Bericht
door rapidos » 18 nov 2010 16:23
Ready for carbonisation: final weight should be around 0.40kg per piece where I planned 0.75kg
Berichten: 2177 Lid geworden op: 06 dec 2006 20:14
Bericht
door Exmantaa » 18 nov 2010 19:52
Carbonisation...
You're going to burn your wing mounts?
rapidos
Bericht
door rapidos » 19 nov 2010 6:36
I have now to build the same shape with carbon fiber...
Bericht
door Exmantaa » 19 nov 2010 10:42
I know of your carbon fetish....
Are you going for a
BIG diffuser like this Speedster?
[/list]
