Pagina 5 van 38
Geplaatst: 22 jan 2008 2:08
door rapidos
This 3.5 stage is provided by Regelin.
Hey Herman,
Nice car ! I won't follow you to that level of power, as it will take me long to use more than 95% of my engine power :oops:
I steel need to find big brakes. Are you happy with the AP 4 pots ? Do they need a special treatment as they have no dust protectors ?
two more questions : Did you weighted them ? Did you weighted your seats are it seems VERY unreal to be below 4 kg as they anounced 1.8 kg...
My car is weighting 849 kg today without fuel but I still need to place the carbon body, the alloy tank, and some other stuff so I will reach this weight by few weeks only.
See you perhaps on track in the Netherlands ! (I planned to go to Zandvoort this year, perhaps the 27/06)
Cheers :D
Geplaatst: 22 jan 2008 7:09
door Herman
Geplaatst: 22 jan 2008 10:50
door rapidos
Don't expect less than 2.9-3 kg without cushion... :wink:
Geplaatst: 01 apr 2008 2:37
door rapidos
One of my friend you perhaps know (V.) has just tested his 3.5, same weight as mine :
100-140 km/h (4th) : 2.4s :shock:
400m D.A.: 12,2s :shock: :twisted:
Geplaatst: 01 apr 2008 6:56
Nice figures!
But a Z06 will hit 100 in 3.9s (manufacturer figure :wink: ), and 200 in 12s. So g-forces will not say a lot in this case :wink:
Geplaatst: 01 apr 2008 12:12
door rapidos
It depends if you believe the newspapers and official stuf or your own mesures... :lol:
Geplaatst: 01 apr 2008 12:41
Looks like a lot of wheelspin for the Z06 in first gear :wink:
Geplaatst: 01 apr 2008 14:51
door rapidos
I don't know :?: :!: I will post my own datas when ready to compare.
Geplaatst: 02 apr 2008 17:28
door Rikster
¼mile: 12.2s@191.25km/h :woship:
I did the ¼mile in 11.9s driving a stage 3 (285bhp) and Drag Radials, but never got over 179km/h :roll: (Probably the slicks slowing me down...)
Geplaatst: 16 apr 2008 12:24
door rapidos
I just received my new tank:
Aluminium made, compartimented, filled with FIA foam, anti starvation system, capacity + 10L, only 6,7 kg against the 10,9 kg OEM.
Geplaatst: 16 apr 2008 16:37
door Rikster
...nice 8)
Geplaatst: 16 apr 2008 17:41
door RCduck7
Great, shaves more then 4Kg of the car.
Where is the tank situated?
I'm looking for weightsavings but only at the middle/back of the car to have a slightly better weight balance.
Any suggestions??
Geplaatst: 16 apr 2008 17:53
door rapidos
The tank is perfectly located, close to the ground behind your back when driving.
Do not forget the perfect balance is not 50/50, but 40/60 like F1 cars... :wink:
Geplaatst: 17 apr 2008 17:10
door RCduck7
rapidos schreef: Do not forget the perfect balance is not 50/50, but 40/60 like F1 cars... :wink:
Yes, i know.
But the speedstar NA is almost 30/70 or something i believe.
That's why i'm looking for (relatively easy) weight savings at the back of the car.
Geplaatst: 17 apr 2008 18:41
Before you start spending zo much money on "I believe" things, you might want to understand what the weight distribution really is :wink:
The last time I weighed my 2.2 it had 340 on front axle and 520 on the rear, with approximately 20liters of fuel on board. This makes exactly a 40/60% distribution :wink:
