Vindt het nog meevallen de prijs voor een zo"n stukje techniek die op het circuit een seconde eraf kan halen is het een koopje.
THE DYNAMIC WING™ ADVANTAGE.
Wind tunnel designed and race-proven, the AeroMotions Dynamic Wing™ gets you around the track faster. Every Dynamic Wing™ is computer controlled, adjusting the wing angle to deliver the right downforce for each section of the track. This plug and play package provides ample downforce when cornering, more downforce under braking, and less drag on the straightaways.
FULLY AUTOMATIC.
Using Patent Pending technology, the ADAPT controller monitors acceleration, braking, speed and lateral G’s to provide the right downforce for every section of the track. These plug and play wings take the guesswork out of your aero package.
SAVE TRACK TIME.
Track time is expensive, and there never seems to be enough. Want to try your own tune? Dynamic Wings™ make it easy. Using the in-car remote, you can add downforce, one degree at a time, with the click of a button. Back-to-back comparisons of hot laps let you dial in the aero like never before.
TWO WINGS. ONE CHOICE.
The R2 Dynamic Wing™ is for Track, Time Attack, and Drifting. It’s available as a complete Dynamic Wing package, or for half the price, as a record-setting static wing that can be upgraded to a Dynamic Wing down the road.
The S2 Dynamic Wing™ is for super cars, and teams that need the best. Internal actuators, titanium hardware, and extreme heat sinking tailor the S2 for mid and rear-engine super cars. With the split wing blade, full track-side tuning, and weighing 40% less than the R2, the S2 is the best Dynamic Wing available.
