Als je nou een klein stuur foutje hebt gemaakt en je moet dan toch de voor en de achterkant vervangen
Best wel leuke body
http://www.ebay.de/itm/OPEL-Speedster-M ... 9897&rt=nc
Body
Re: Body
Acties
Markus Palm (info@mpm-sportcars.com)
Toevoegen aan contactpersonen
15/08/2012
Foto's
Aan: Dré vandersmissen
hello andre,
our car is also based on the lotus chasis(we use opel-vauxhall speedster-220) and itis also possible to change the body of your elise,if you want. our yellow car is the turbo stage2 tuned with a lot of extras, öhlins, pu-bushings , big brake(308) , steeltubingbr.19" rims(forged lightweight) and,and,and.
there is also a body-kit available, always komplete kit to transfer your car in a thunder, starting at 5990€(with a bit of work on the gfk) -10990€for the plug and play kit (this kit is kompled mounted and finished in ground coat, ready to paint)
you see at this time our yellow one is the cheapet way to drive a thunder, because you take a set and drive....)))
if ther are some more questions, dont hesitate to contakt me.
sorry for my bad english, still learning:))))
greets m.palm
Als je hierover meer wil heb ik volledige info hieromtrent. Wou de stap zetten maar is niet homologeerbaar in Belgie...
15/08/2012
Foto's
hello andre,
greets m.palm
- timmyboy55
