rapidos
rapidos
Bericht door rapidos »
Exmantaa schreef:Those bolts will not fit into the hubs, as the hub bolts are mounted/sunken a few mm into a bore hole of the hubs. You need the CHC types. Ask forum, a Lotus dealer or look on Ebay.co.uk. You see them often under Elise or vx220 parts...
Look what they sell here for the hubs...
http://www.lir-racing.com/catalog/produ ... cts_id=184
http://www.lir-racing.com/catalog/popup ... hp?pID=184
Not gonna fit unless some sort of spacer is used under the bolt head.
If you look at the diagram:
Bolt number 5 is one of those we're talking about?
The bolt head sits in a recessed area in the mounting plinth.
Only an allen-head (or Torx) bolt will fit there.
If a normal hex-head bolt is used it will not sit flush/even as the mounting plinth does not have a flat surface.
rapidos
Yep, thanks Arno, but I confirm they sell and use these ones without problems on all cars mounted. Eventhough, I will use the Hexagonal one... :wink:
Here a crude sketch how the bolt is recessed in the front hub assembly.
A normal flathead bolt will not fit in there without some spacer bush...
Front hub arm
Front hub arm
hub oic.JPG (29.79 KiB) 2933 keer bekeken
rapidos
It seems they use the flathead for rear only.
As it looks the rear hub bolts are not recessed, so the flathead bolts should fit there.
Hub rear
Hub rear
Hub rear.JPG (30.64 KiB) 2895 keer bekeken
rapidos
It seems I need also the hexagonal screws for the rear...
and front
rapidos
I have got them now. Will fix with 65Nm
rapidos
dat is de inbraak ?
A 4 wheels boot... :lol:
alain
Bericht door alain »
[quote="rapidos"]dat is de inbraak ?
Cool !!
Lotus Antwerp changed my bolts last week and they where realy close to brake !!!!
The bolts where vissibly bended from the stress !!
I think everybody should check them before its too late !!!
Alain
Laatst gewijzigd door alain op 25 aug 2008 16:00, 1 keer totaal gewijzigd.
rapidos
alain schreef:Lotus Antwerp changed my bolts last week and they where realy close to brake !!!!
Ouch, so it was close...
rapidos
Here is my new sport catalysor in place. The engines works better with this, no doubt.
I also have a new exhaust simple exit. The main idea was to light weight the car at the rear, estimated by 0,6kg. Here the "old" two tube section :
And the new simple one:
Weight saved : 1,86 kg :P
Rikster
Bericht door Rikster »
Looks like it will be loud!!! :shock:
rapidos
99.7 dB, but mainly coming from everything but the exhaust exit :lol:
I also changed the rear hub screws, that were still in perfect condition... So I decided not to touch the front.
rapidos
Here is the work of my day : -0.5kg :D
As I could not determine which resin was used to build the carbon leave, I had to build my owns with Epoxy resin, to avoid any fire problem, specialy for the rear one (coming soon...)
