rapidos
rapidos
Bericht door rapidos »
Front lights are now ready to receive their fake sticker...
Weight saving : -0.86kg per side !
rapidos
jaydee
Bericht door jaydee »
The lights look really good! But it seems that the LEDs are not giving enough resistance, so the indicators blink too fast.
And do you have a Peugeot alarm with those manic blinks at the beginning? :mrgreen:
Jägertee
rapidos
I need your help. Do you know what relay (K31) should I put to reduce turning lights speed please ?
http://www.speedsterclub.nl/bibliotheek ... 0panel.pdf
Thanks.
:wink:
jaydee
I don't know this. Smiley probably has some bookmark that will explain ;)
Otherwise exmantaa and manta79 may know. They have made contributions to the forum about electrical stuff that suggest so...
Jägertee
I'll do my best, but the turn signal unit K31 is build for the resistance of normal light bulbs. (therefore it flashes quicker when 1 bulb is broken...)
I would keep the standard relay and adjust for the resistance of your LED units. Looking to the diagram (http://www.speedsterclub.nl/bibliotheek ... 0lamps.pdf) you probably only need to change the resistance in the output wire on pin 3 of K31.
joel do desert
Bericht door joel do desert »
Rapidos,
I had the same problem and I've changed the relay for a LED FLASHER FLASH RELAY see link.
http://cgi.ebay.nl/ws/eBayISAPI.dll?Vie ... SA:NL:1123
Even better !! :wink:
rapidos
The perfect solution :D
Thanks a lot ! :wink:
rapidos
In the oven today...
rapidos
rapidos
Sure ! Thanks :wink:
rapidos
Which one is the best for you please ?
version 1 :
version 2 :
version 3 :
version 4 :
version 5:
Thanks !
i think version 3
grt speedokus :D
