rapidos
rapidos
Bericht door rapidos »
Before the season starts, I used an old rush, not perfect quality but still...
http://videos.streetfire.net/video/Traf ... 210168.htm
:wink:
Herman!!! Isn't that you at 1.03 that gets lapped. :P
Nice vidio, you must have some non-oem-power-goodies under the hood. :wink:
Dominique schreef: Nice vidio, you must have some non-oem-power-goodies under the hood. :wink:
The specs:
http://www.rugissante.com/3.html
Would make an interesting day at the track with Herman and and Rikster.
rapidos
2316 minus 1717 = 0,60kg
Laatst gewijzigd door rapidos op 10 jan 2009 14:43, 1 keer totaal gewijzigd.
Rikster
Bericht door Rikster »
Sparco model, right? Very nice... 8)
Did you also remove the airbag control unit under the dash? :idea:
rapidos
Rikster schreef:Sparco model, right? Very nice... 8)
Yep, called SRS (Siemens).
alain
Bericht door alain »
How do you do for the controle technique in Belgium ?
rapidos
I will fit everything back, of course !
rapidos
Yesterday work :
New rear discs are ready : -3kg !
This is my second heat protection prototype for the toe-link :
Here is the new position of the ECU as there is no boot anymore in the car.
rapidos
Today, the front toeing eye : -0.32 kg
Mine is now integrated, in alloy 5mm FIA size. I will paint it in red.
I also started something nice... :twisted:
Laatst gewijzigd door rapidos op 16 jan 2009 14:20, 1 keer totaal gewijzigd.
Ah, new curtains!? :idea:
You must have switched to home decoration then? :lol:
Looking very much forward to the first pics of your carbon dash!! 8) :thumbup:
rapidos schreef:Yesterday work :
For the best shielding you may want to make those out of Cirrus or Nimbus sheeting:
http://www.nimbusmotorsport.com/ProdSho ... &CATID=252
http://www.nimbusmotorsport.com/newsima ... eld.v1.pdf
It re-transmits very little of the heat it receives on one side to the other side. Works great!
rapidos
Arno schreef:For the best shielding you may want to make those out of Cirrus or Nimbus sheeting:
Thanks Arno, it's a very good idea but that kind of product is not thick enough as there is very little space between catalysor and toe-link, I would say just 5mm... I can make a try anyway ! :wink:
rapidos
The catch tank and it's high flow pump are fixed on this 2mm alloy sheet:
...and fixed on the boot motor side. But I have no boot with my new rear pc...so I had the choice either to fix in on that:
fixed on the chassis or.....CF/epoxy home made suport:
So 0.36kg saved on the rear :D
