Blijkbaar kunnen ze deze dan ook aanpassen aan de eisen van de klant.
BILSTEIN SERVICES - Official Bilstein Shock Absorber Shop Services
Revalve or Complete Rebuild (utilizing existing or recommended valvings) Standard shock (mono-tube Non-adjustable) $65.00 each
Struts (mono-tube Non-adjustable) $75.00 each
Single adjustable (Examples incl. Corvette and Ferrari) $100.00 each
Single Adjustable w/ knob (Examples incl. PSS9 and Motorsports) $125.00 each
Double Adjustable w/ reservoir $175.00 each
NOTE: All revalved shocks and struts are dynamometer performance checked. Additional parts and services that are not included in the normal scope of revalving will incur an additional charge (examples include shock rods, tubes and/or end loops and machine work). Development fees apply if it is necessary to meet specific valving targets.
Replace piston rod (Appropriate rebuild fee from above must be added) Non-adjustable (Standard in stock rod) Add $10 each
Non-adjustable (Non-standard / Non-stocked rod) Add $10 ea. plus
$45.00 per hour machining fee
Adjustable (Standard in stock rods only) Add $45 each
Additional Services External snap ring grooves $10 each
Strut bearing replacement $100 each strut housing (subject to availability)
Tube replacement $30 per unit avg. plus rebuild fee
New mounting parts component price
Dyno evaluation $25 each with print out (standard on request with revalve)
Shop labor $60 per hour (including machining & welding)
Rush service (1-2 days) $35 per unit plus rebuild fee
