Forge RS valve (recirculated)
Te koop en nooit gebruikt.
25mm/34mm in/uitgang (Evo 9 type)
Nieuwprijs: 250 euro Zonder verzending bijgerekend)
Mijn prijs 240 euro verz. inc
Is ombouwbaar tot open dumpvalve (onderdelen afzonderlijk bijkopen wel)
The Forge RS valve has been specifically designed and engineered, to offer extreme flow rate capability, where other valves are just not up to it. Often when engines have been tuned by installing larger turbos or even software upgrades improved turbo response can be acheived by fitting the RS valve which has the greater internal mass air flow specification utilising an amazing 50mm (2") bore. For fine tuning there is a variable spring preload incorporated and a ratchet type top adjuster that will allow for the positive and precise adjustment that your driving style demands.
To ease installation. a 360 degree adjustable vacuum hose connector. With a choice of inlet and outlet connections the RS valve can be matched to your engine perfectly. This valve incorporates a unique conical, progressive rate spring that can allow for the retention of boost pressure from 7 to 22 PSI depending on the individual user's application and level of adjustment. If you are intending on running over 22psi then you will need the uprated spring, which is included in the kit.
This unique spring design will also allow for unrestricted piston travel and flow volume regardless of the amount of pre-load adjustment added to the spring. Other manufacturers valves using cylindrical springs with adjustable pre-load often experience restricted piston travel and flow volume within the normal range of valve adjustment.
Voor big ass turbo's :wink:
Reden te koop (uitlegje voor Daan)
custom valve ( en compact)van GFB ontvangen die het perfect doet.... De Forge is dan ook 13cm lang en bijna 6cm breed!!! (een kleine penis dus :lol: )
De GFB is ook stiller (jammer genoeg) maar driveabillity is veel beter
Winspeed
Re: Forge RS valve (recirculated)
Bericht door Winspeed »
Volgens mij heb je heel de markt al afgedaan ondertussen qua bov's :lol:
:lol: :lol:
Bericht door timmyboy55 »
Heb jij nog een kleine verenset Tibby?
Nope, alles weg....
tibby schreef:Nope, alles weg....
Wat heb jij nou aan jou :lol:
Je moet ff de Forge FDV004 halen... blaast tieeeeeefus hard af!
timmyboy55 schreef:Je moet ff de Forge FDV004 halen... blaast tieeeeeefus hard af!
Been there, done that :lol:
https://www.speedsterclub.nl/forum/view ... ge+fmvd004
Winspeed
Tuurlijk da :lol:
Bedankt voor de uitleg :lol:
Verkocht !
slotje op aub!
