rapidos
rapidos
Bericht door rapidos »
In order to definitley solve the fuel straving problem and to be sure the engine is beeing fitted with enough fuel in any conditions, I fitted a fuel catch tank (0,7kg including tubes)
and a high flow fuel pump (0,3kg with aluminium plate) Afbeelding
The car is now running perfectly, around 7s from 100 to 200 km/h in 5th gear.
alain
Bericht door alain »
Was the fuel the problem of your powerloss?
How much Hp do you have now ?
ALain
rapidos
alain schreef:Was the fuel the problem of your powerloss?
ALain
Hey Alain !
No, I had few thinks to be sorted out. Now the boost and overboost are ok but I still need some fine tuning to get the best of this. I am around 290 BHP and 470 Nm for 837 kg : that makes 100km/h to 200 km/h in 5th gear in 7s. I still need to get the best of the intercooler, air admission and put a sport catalyser to get back the last 20 BHP.
See you !
rapidos
alain
Nice weather ! :D
A lot of slower cars on track !!
Did you take some time's ?
rapidos
I could not go faster than 2'56'' as I was overtaking all the time but good fun !
Robin
Bericht door Robin »
Nice movie, nice driving and nice camerawork :thumbup:
12Esc
Bericht door 12Esc »
funny how you try to save weight where possible and drive with three cams in the car...
Bu good for us, nice movies to watch (and i like the soundtrack)
rapidos
Right ! And think about my passengers... the "smallest" one 88kg :cry:
The 3 cameras plus recorder, mic and wires are... 1kg.
rapidos
I just received my sport catalyser, unfortunately quite heavy stuff, but I should get 10-15 BHP with it, and some high quality screws for the wheels...
What kind/brand of cat is that? 200 cell metal matrix??
And where do the 10.9 bolts go? Not the normal upgrade 10.9 hubscrews, as these are "inbus" types...
rapidos
Exmantaa schreef:What kind/brand of cat is that? 200 cell metal matrix??
The catalysor comes from HJS : http://www.hjs-motorsport.de/
I hope I will succeed in fitting them as they are for the hubs... I could not find any CHC screws so...will try those. :lol:
Those bolts will not fit into the hubs, as the hub bolts are mounted/sunken a few mm into a bore hole of the hubs. You need the CHC types. Ask forum, a Lotus dealer or look on Ebay.co.uk. You see them often under Elise or vx220 parts...
rapidos
Exmantaa schreef:Those bolts will not fit into the hubs, as the hub bolts are mounted/sunken a few mm into a bore hole of the hubs. You need the CHC types. Ask forum, a Lotus dealer or look on Ebay.co.uk. You see them often under Elise or vx220 parts...
Thanks :wink:
alain
Ik ben vandaag bij Lotus in Antwerpen langs geweest.
Ze gaan er de bouten van een Lotus Europa op monteren.
+ Toe links van Elise :D Parts
